Leveling options with body kit??
I have a 2003 screw with a 3 inch body lift but it still leans to the front with the torsion bars run up as well. i need an inexpensive way to level the truck out and i dont want to spend over a thousand dollars for a 2" kit! help!
They do the same thing as cranking up your torsion bars which is to increase the preload. The aftermarket keys just let you put more preload on your torsion bars which will put your CV joints at a severe angle. This will increase wear and tear as well as make your ride stiff.
Yeah, I already ran the torsion bars up and Wandell is right, any more height on the torsion bars is not a good idea. Where can i get ahold of some of these shims you are talking about? or at least where can i get some information on them
