Sponsored by: CARiD
Suspension lift help...
Old May 25, 2006 | 08:09 PM
04 Supercrew's Avatar
Arrow Suspension lift help...
Looking to buy a 4" or 6" suspension lift. Need your opinions on the best lifts out there. Looking at the Pro Comp 6" lift w/out the coil overs, but am open to other suggestions. Going on a 2004 XLT 4x4 with 325/60/18's. Thanks.
Old May 25, 2006 | 10:51 PM
patshea098's Avatar
dont go with pro comp unless you get the coilovers cause then you jsut get spacers up front. go fabtech or rancho which is really a 5.5 lift. you could also go skyjacker.....more expensive though. i say fabtech....i personally have pro comp with coilovers
Old May 25, 2006 | 11:22 PM
How do you like the Pro Comp lift with the coil overs?
Old May 26, 2006 | 03:35 PM
wandell's Avatar
There is nothing wrong with the Pro Comp lift, but I think the Fabtech, RCD and Rancho lifts are made better.
Old May 26, 2006 | 03:42 PM
sean_somer's Avatar
i agree with most everone, ive had bad luck with skyjacker so i no longer used them, in my opinion use either rancho or fabtech
