Sponsored by: CARiD
expedition camber kit question
Old May 13, 2006 | 03:02 AM
cincinnatiscrew's Avatar
hey fellas, i will be replacing the drivers side control arm and ball joint, i read alot about needing the camber kit as well, i am replacing w/ stock control arms, is this kit really necessary?
qalso replacing idler and pitman arm...any tips??
Old May 14, 2006 | 10:54 PM
Yankee7985's Avatar
Why only one side? If I were you, I would replace both sides unless the other side has already been done. You will most likely need the camber kits. The OEM kits only allow for a certain range of adjustment. The kits are only $8.50 at www.fordparts.com. You will need (4).
