Sponsored by: CARiD
Cutting Tranfer Case Shifter
Old Mar 30, 2006 | 01:17 AM
deerfeedrb's Avatar
I read through the instructions for the 04-05 PA 3" body lift. The only part I didn't like was where it told me that since I had the manual transfer case shifter, I would need to cut it and weld in the extension. The pics in the instructions don't look like my shifter of course.
Has anyone installed a body lift with a manual transfer case? I'd like to hear comments on your experience extending this shifter. It seems that if I extended it 3 inches, there would be a lot of travel in the end of the shifter and other modifications may need to be made. Could I get away with not cutting the shifter?
I can do everything but would have to pay to have the shifter welded. This step is the only thing holding me back from buying the kit; I'm just not comfortable with it. Thanks.
Old Mar 30, 2006 | 07:59 AM
wandell's Avatar
The first body lift I ever installed was on an S-10 with a manual transfer case shifter. I didn't extend the shift lever, but I had to trim the sheetmetal on the floor slightly for enough clearance for the shifter to engage 4-Lo. The shift lever just sat really low.
Old Mar 30, 2006 | 09:10 AM
deerfeedrb's Avatar
Makes sense. On the new body style, they have this plastic cupholder thing that goes around the shifter. I think that even if I extended the shifter, I would still need to make some modification to it. I'm sure someone has tried it, but not many. Maybe I need to give PA a call.
Old Mar 30, 2006 | 03:54 PM
wandell's Avatar
That would be a good idea.
Old Mar 30, 2006 | 03:58 PM
BJN708's Avatar
Mine was standard transfer case. It's not hard to just cut it and weld a 3" rod in btwn. Would prolly save you time and i think its the better way to go. Just my opinion
Old Mar 30, 2006 | 10:50 PM
deerfeedrb's Avatar
I called PA today and spoke with a tech guy. He sounded pretty familiar with the new body style transfer case and understood my concerns. He told me that I might have to do some trimming and bending of the shifter. He said that after I weld the extension in I might have to do some heating and bending to optimize the position to reduce trimming. I also rolled under the truck to look at the shifter and it appears to make several bends, but I think I could get it to work.
