Sponsored by: CARiD
pinion angle
Old Mar 23, 2006 | 08:46 PM
joshcblue's Avatar
pinion angle
does anyone know teh correct pinion angle for an 02 screw?
thanks
Old Mar 23, 2006 | 09:22 PM
metallion's Avatar
need to know what engine, trans, wheelbase, and if it is 4x4 or 4x2.
Old Mar 23, 2006 | 09:46 PM
joshcblue's Avatar
is an 02 screw 4x2 5.4 auto
Old Mar 26, 2006 | 10:51 AM
Dbl G's Avatar
This should help you out.
http://www.nhtoc.net/vbforum/showthread.php?t=18885
Old Mar 26, 2006 | 07:27 PM
metallion's Avatar
WB -Trans - Eng -Eng Angle -Trans/Center UJT Angle -DS Angle -Pinion Angle
139 - E4OD - 5.4L - 4.5 deg - 0.73 deg - 5.3 deg - 4.7 deg
139- 4R70W - 5.4L - 4.5 deg - 0.70 deg - 5.3 deg - 4.5 deg
This may help. Good luck!
Old Mar 27, 2006 | 08:45 AM
joshcblue's Avatar
ok.. thanks guys..
now is that positive or negative past zero? ie is the chunk angled into the bed or into the ground?
