Sponsored by: CARiD
Lift Spindles, Springs, or Spacers?
Old Mar 15, 2006 | 04:11 PM
ameration's Avatar
I am thinking of lifting my 4x2 a few inches and was wondering if Lift Spindles are the way to go? Do you need to get it re-alligned after installing the spindles?
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
Or are the Coil Springs or Spacers the way to go?
http://cgi.ebay.com/ebaymotors/LEVEL...44789340QQrdZ1
Old Mar 15, 2006 | 04:13 PM
wandell's Avatar
It just depends on how high you want to go. Personally, I'd install both. Also, it is a good idea to have the alignment checked although some say it isn't necessary with just spindles.
Old Mar 15, 2006 | 04:20 PM
ameration's Avatar
Pros and Cons of each? I am only looking at maybe 2-3".
Old Mar 15, 2006 | 04:26 PM
wandell's Avatar
THe spacers are less expensive, but you may need an adjustable camber kit (around $50) to get your alignment correct. The spindles will give you a little more lift but will increase your front track width a couple of inches.
Old Mar 15, 2006 | 07:08 PM
Bartak1's Avatar
If you on a budget and just want a couple inches spacers would be the way to go. I like spindles best. I have a 3.5 lift on mine. It needed re-alighned big time.
