Sponsored by: CARiD
torsion bar keys ?
Old Mar 11, 2006 | 04:24 AM
redbats21's Avatar
torsion bar keys ?
has any one used torsion bar keys to lift the front end of their truck an inch or two? someone was showing me thier truck after doing that and i didnt know the positives and negatives of doing that. it seems like an inexpensive way to lift the front a little.
also, if i were to do that, is there a recommendation how to level the rear end to match? add a leaf spring, or maybe blocks? which would be safer?
thank you for any advice!
Old Mar 11, 2006 | 10:15 AM
wandell's Avatar
I wouldn't do it. All they do is allow you to put more preload on the torsion bars. You can do the same thing with your stock adjustment keys. A lot of people think that cranking the stock adjustment keys up all the way is a bad idea because you can get the CV joints at a more severe angle that will cause increased wear. The aftermarket keys just let you put even more preload on the bars. I would save your money and just crank the stock adjustment keys up to level the truck. Don't forget to have your front end aligned if you do this.
Old Mar 12, 2006 | 11:09 AM
redbats21's Avatar
thank you for the info!
