Sponsored by: CARiD
Total Cost?
Old Mar 9, 2006 | 04:48 PM
speeddemon13's Avatar
Total Cost?
What should the total cost be for getting a 3" body lift and installed, 35" tires, 4.56 gears and installed? How much should all of that cost, that is everything needed to have a reliable 3" body lift right?
Old Mar 9, 2006 | 04:54 PM
Bartak1's Avatar
Well, the gear swap is going to be around 800-1000 bucks (assuming you have a 4x4), mounting and balancing for the tires will be around 50ish bucks (usually 10 or so bucks a tire around here) and as far as the BL goes, I have no idea. 200 bucks maybe?
Id say around 1500 bucks when its all done, give or take. Just depends where you get it done.
Old Mar 9, 2006 | 05:05 PM
tonka357's Avatar
$5500 this price includes 3" body lift kit, labor to install kit, wheels/tires, new gears,labor for regearing, reflashing your computer, frontend alignment, modify front horns for front bumper, side steps, and gap guards.
Old Mar 16, 2006 | 07:44 PM
chroma's Avatar
$5500 seems incredibly steep for a body lift, tires, and gears. Are you sure you're not quoting a suspension lift kit? I can't imagine anyone doing a body lift for that kind of money.
Old Mar 17, 2006 | 10:18 AM
tonka357's Avatar
Well just for the body kit and install about $1500, for 4 tires not rims $1000, if you have a 4x4 front and back regearing $1200. Job cost if someone does everything for you $3700.
Old Mar 29, 2006 | 11:49 PM
bigyellowtruck1's Avatar
Body lift-$150+ $90 [gap guards]
Install-$600-$900 [takes anywere from 7-12 hrs normally]
tires-$1000- roughly
install tires, balance and allignment-$250
gears-$400 front and rear
install-$800-$1000
total cost roughly-$3500
Old Mar 30, 2006 | 11:22 AM
twstd02's Avatar
$5500 =
Thats what I paid for my Suspension Lift, Wheels, Tires, and installed!
Reflashing the computer is a matter of a few minutes, and if the so called Suspension Shop has ever done this before should hae the tool to fix that and shouldn't RAPE you for it that bad (if they charge you more than $75 to do it, take it to the Dealer)
I got a quote for $600 for install of my Body Lift. I also live in lift kit country, so the prices should be high. I think the quote you should be looking for is between $600 and $800.......Not $1500.00
The kit also comes with Bumper Brackets = no messing with frame horns
Gap guards are $80
you can find a decent wheel/tire combo for about $1,500
Gears should be $1,000 +/-
thats a first i've heard of a front end alignment after a BODY LIFT!
but since you are upgrading your tires to a bigger size, then MAYBE.
But all in all the total price with tax should be around $3,500
$5,500 is OUTRAGEOUS!! you would have to be a dumb mothaphuker to pay that
Thats my opinion on the whole thing
Old Mar 30, 2006 | 06:21 PM
04procompLARIAT's Avatar
ditch the body lift and go with full suspension! youll be way happier in the long run!
Old Mar 30, 2006 | 08:51 PM
speedstang's Avatar
04procompLARIAT is right. I did everything myself except for the alignment. With the 6 inch fabtech suspension lift and 35 inch tires it came out to about $2300 or so.
Old Mar 30, 2006 | 10:27 PM
slimshady0479's Avatar
What is used to lift the front end of a 4x4?
Old Mar 31, 2006 | 11:08 PM
speedstang's Avatar
A bunch of stuff, but the main things, longer spindles, front and rear crossmembers to lower the bottom a-arm, and drop down bracket to lower the rear mount for the torsion bars.
Old Apr 1, 2006 | 02:04 AM
is all of that stuff necassary with a 3" body lift?
Old Apr 1, 2006 | 12:32 PM
speedstang's Avatar
All the stuff I listed is used when doing a suspension lift. For the body lift you will be putting 2 or 3 inch spacers, whatever you decide, between the body of the truck and the frame. Plus whatever bumper relocating brackets they give you.
Old Apr 7, 2006 | 09:46 PM
NWAF-150's Avatar
i agree if you have any mechanical ability and a friend you can do a body lift no problem i have done 2 and there really not that bad just time consuming,
Also i just bought new wheels and tires but am considering a lift kit now would a lift with just 33's look bad i dont really want to shell out another 12-1500 dollars on new tires again the ones i have are only 3 weeks old
Old Apr 12, 2006 | 11:07 AM
crash_lucky13's Avatar
sounds like someone got you good..
who did you go through? try emailing this guy for a good quote on the parts
sportztrailersjosh@comcast.net
i just scanned through your parts...but even your gap gaurds you can get for $20 cheaper through him....
tell him you are from f150online
