Which Lift kit?
Which Lift kit?
Wanted to lift my 2005 2wd ford f150 and was wondering if anyone had suggestions and what i should do... I was thinking of a 4-6 in lift but didnt want to spend a lot of money, Suspension kits are kinda much and was thinking of maybe just a body kit lift or something a little cheaper any ideas?
YOu could get a 3 inch body lift, but sometimes(if not done right) there is some squeaking from the body on the spacers. Also some don't like the look because of the gap created between the body and frame. It is a cheap alternative. Also there is a 3 inch skyjacker lift for about 650+/-. Or there are some lifts that are more economical such as rough country/ tough country. Definitley look around and get informed before you make your purchase. Good luck
If cost is an issue, I'd go with a 3 inch Performance Accessories body lift and a Autospring leveling kit. Just be sure to get a set of PA's Gap Guards to cover the gap between the body and frame.
