Sponsored by: CARiD
Alignment specs for 99 4x4
Old Dec 19, 2005 | 11:00 PM
KDOTengineer's Avatar
I did a search for alignment specs, and all got were specs for Lightnings. I'm guessing they're somewhat different than 4x4's or just regular 150's.
Could someone please post them or direct me to them. My Chilton manual doesn't have them. I want to have these on file for a possible future alignment someday. Thanks.
Old Dec 19, 2005 | 11:24 PM
lees99f150's Avatar
google is your friend.
bad link. they want money for the info.
Bastards
Old Dec 20, 2005 | 08:14 AM
yeah i didn't have a whole lot of luck with google
Old Dec 20, 2005 | 12:36 PM
GIJoeCam's Avatar
Sorry about the porr formatting.... it doesn't copy and paste well....
General Specifications Item LH RH Total/Split
Alignment Specifications — F-150, 4x2
Caster 6.2° ± 1.0° 6.7° ± 1.0° -0.5° ± 0.7°
Camber -0.3° ± 0.7° -0.3° ± 0.7° 0° ± 0.7°
Toe (positive value is toe-in, negative value is toe-out) 0.03° ± 0.15° 0.03° ± 0.15° 0.06° ± 0.25°
Alignment Specifications — F-150, 4x4
Caster 4.6° ± 1.0° 5.3° ± 1.0° -0.7° ± 0.7°
Camber -0.1° ± 0.7° -0.1° ± 0.7° 0° ± 0.7°
Toe (positive value is toe-in, negative value is toe-out) 0.10° ± 0.15° 0.10° ± 0.15° 0.20° ± 0.25°
Alignment Specifications — Lightning Vehicles
Caster 6.7° 7.2° –0.5° ± 0.7°
Camber –0.5° –0.5° 0° ± 0.7°
Toe (positive value is toe-in, negative value is toe-out) –0.05° ± 0.15° –0.05° ± 0.15° –0.10° ± 0.25°
General Specifications Item Specification
Dogtracking — maximum (centerline of front tires compared to centerline of rear tires) 30 mm (1.2 in.)
Clear Vision
Clear vision (negative value is counterclockwise) -0.7° ± 3.0°
Vehicle Ride Height — F-150, 4x2
Front — Regular Cab 114 mm ± 20 mm
(4.5 in. ± 0.8 in.)
Front — SuperCab 122 mm ± 20 mm
(4.8 in. ± 0.8 in.)
Rear 153 mm - 215 mm
(6.0 in. - 8.5 in.)
Vehicle Ride Height — F-150, 4x4
Front — Regular and SuperCabs 113 mm ± 19 mm
(4.4 in. ± 0.75 in.)
Rear 150 mm - 205 mm
(5.9 in. - 8.1 in.)
Vehicle Ride Height — F-250, 4x2
(4.5 in. ± 0.8 in.)
(4.8 in. ± 0.8 in.)
Rear 173 mm - 235 mm
(6.8 in. - 9.25 in.)
Vehicle Ride Height — F-250, 4x2, w/Load Leveling Suspension
(4.5 in. ± 0.8 in.)
(4.8 in. ± 0.8 in.)
Rear 83 mm - 101 mm
(3.3 in. - 4.0 in.)
Vehicle Ride Height — F-250, 4x4
Rear 170 mm - 225 mm
(6.7 in. - 8.9 in.)
Vehicle Ride Height — F-250, 4x4, w/Load Leveling Suspension
Rear 80 mm - 98 mm
(3.1 in. - 3.9 in.)
Vehicle Ride Height — Lightning Vehicles
Front — Regular Cab 100 mm ± 20 mm
Rear 121–140 mm
Ball Joint Radial Play
Lower ball joint — maximum 0.8 mm
(1/32 in.)
Upper ball joint — maximum 0.8 mm
(1/32 in.)
Vehicle Lean (Side-to-Side Height Differences)
Front — maximum 12 mm
( 0.5 in.)
Rear — maximum 19 mm
(0.75 in.)
Torque Specifications Description Nm lb-ft
Front suspension upper arm cam bolt 113-153 84-112
Toe set jam nuts 77-104 57-77
Old Dec 20, 2005 | 10:12 PM
Wow like a walking service manual....
Thanks for the info man!
Old Dec 21, 2005 | 07:28 AM
GIJoeCam's Avatar
I'm not smart, just a resourceful idiot that had a slow day at work.
