Sponsored by: CARiD
Superlift or Skyjacker??
Old Dec 12, 2005 | 03:55 PM
drewschbagg's Avatar
I think I have finally narrowed it down to these two choices - either the 5" Superlift or the 6" Skyjacker. What are your guys' opinions on these two suspension lifts? I might also add a 2" Performance Acces. body lift on top of the susp. lift. I'm thinking 37x12.5 tires with the susp. and body lift--let me know if I'm wrong.
Old Dec 12, 2005 | 03:56 PM
wandell's Avatar
What kind of truck do you have?
Old Dec 12, 2005 | 04:12 PM
I have a 97 F150 XLT (std cab, short bed, 4.2L V6, 5 spd transmission)
Also, I just noticed this with buying a Skyjacker system...
"Regular Cab, Short Bed Models, are equipped with a factory tapered 2” Block. For correct driveline angle, a flat 2” block will be needed. Available from Ford Dealer."
Does anyone have any clue about how much this block costs, and if I can get it from anywhere other than Ford dealership?
thanks.
Old Dec 12, 2005 | 06:55 PM
dodge_slayer01's Avatar
try suspensionconnection.com they sell lift blocks made by tuff country i think they have tapered and flat blocks.
lata
Old Dec 12, 2005 | 07:56 PM
4.64x4's Avatar
two things, first ignore dodeslayer (cool name though), dont buy anything with tough or rough country on it. trust me u will regret it. and seccondly, u will need some major gear modifications if u want to run 37's with a v6. i would look into gears before the lift.
keep it ford
Old Dec 12, 2005 | 08:37 PM
What gears are recommended? What's the difficulty? Cost?
What tires/wheel size would I be safe running with the stock 4.2L gearing?
Old Dec 13, 2005 | 03:52 PM
bigtruck311's Avatar
37" with the V6 i would recomend 4.88, install cost varies from regions but it is pretty pricey, $200-500 per axle, if you have never been inside a diff i would recomend finding a freind who you trust that has done a ring and pinion before or take it to a trustworthy shop, good luck
