Sponsored by: CARiD
75-80 MPH Vibration
Old Dec 2, 2005 | 06:01 AM
tecleme's Avatar
Exclamation 75-80 MPH Vibration
Have a 2WD SC with 3 or 4" body and a 6" suspension lift. has a 75-80MPH vib. was tolt that I do not need a 2 peice driveshaft but could this cause it. the trans seems ok (pink fluid shifting no leaks) had tires and alignment ck also
Old Dec 12, 2005 | 08:30 PM
91_F-150_Man's Avatar
shims
If you have a 2 piece shaft then try adding and removing shims between the carrier bearing and the crossmember.
