Trailmaster 4" Suspension Lift Question
I just ordered a 4" trailmaster kit. I was wondering if I will need any extra parts to install the kit(ie extended brake hoses, etc)? Is the trailmaster a good kit, i have been reading things on this forum and some say good and others say no.
It will be mostly street driven and some off-road, but nothing to harsh
also i payed a little of $1200 for the kit w/ssv shocks is that a good deal?
Todd
Todd
Yeah you will need new extended brake hoses front and rear. I used 4-6" lift skyjacker brake hoses. They are cheap and really nicely made. But there are other brands out there I am sure that are just as good or better.
Jay-D
GOODLUCK!
Jay-D
you can bend your stock hose were it is metal above the flex hose down a few inches and then redrill the holes for the bracket, this will give you enough length for a 4" lift kit, anything more than 4" i recomend getting some steel braided lines, i had mine custom made at a hose shop for $60 dallors a pair, it was a shop that did hoses for race cars and the like, if you ask your local speed shops they should be able to point you in the right derection, good luck
