Sponsored by: CARiD
Lowering the rear end
Old Nov 13, 2005 | 11:49 AM
chub's Avatar
I have a 03 supercrew 4x2 that I would like to lower the rear about 2-3 in is there a cheap easy way to do without messing anything up?
Old Nov 13, 2005 | 12:50 PM
tigga83's Avatar
yeah...if your 4X2 is anything like the 2005's, than there is no block in the back, so i would just buy some lowering shackles....and the back will come down noticeablly, but if you do have blocks, i would just go ahead and remove those.
Old Nov 13, 2005 | 04:22 PM
Bartak1's Avatar
The 2wd's do not have blocks in the back, so, as tigga said, go for some shackles.
You can get different lengths, but most are 2 inches, which will mak your truck sit level. You can get a pair of shackles for around 50 bucks to, and they are easy to put on yourself.
If you only go 2 inches, your probably wont NEED some shims, but its not a bad idea to have some. They go between your axle and leafsprings and tilt the axle a little, to get the driveline staightened back up. I think with 2 inch shackles most people go for 2 degree shims.
Good luck.
