Front End, Thump, Clunk, Clank
I know this topic has been covered alot but i stall can't find the problem.
I have a 2001 F150 Super Cab. There are 47,000 miles on it and i have a clanking or clunking noise coming from the front passenger wheel. I have replaced the Inner and Outer tie rods, sway arm bushings, sway arm links, and indler arm on that side. I have also torqued the bottom shock bolt which went maybe 1/2 turn. When i drive over an area where they have patched the road it is most noticeable and it feels like the whole tire is gonna come off. Does anyone have any other areas I should check?
Originally Posted by bigdaddyII
Check both your upper and lower balljoints. If they are bad, you are very correct in the above statement. If left alone, thats what just may happen.
Originally Posted by bmgnitro
I have had them checked, maybe i will get a second opinion.
I guess it is making more of a "Klucking" sound.
I have been to 2 dealer and one small shop and they say it is all tight, but yet this noise is loud enough to know something is still wrong
What's Next?????????
same thing drove me crazy. The upper ball joint was shot. To check it, jack up the truck so the wheel is of the ground. jack from the frame so you don't bind any suspension parts. A floor jack up front on the lower frame under the front diff works great. now try and move the wheel top to bottom and in and out. if its loose then you have a worn part in there. check both sides.
There is some play left to right, but none top to bottom, is that still symptoms of a bad ball joint?
left to right would be in the steering linkage. a worn tie rod end, idler arm or pitman arm. see if you can isolate it. With the truck on the ground and the engine off, have someone move the steering wheel back and forth while looking at all the linkage for excessive movement in the joints and pivots.
Originally Posted by Nbr6car
It's not suspension related, but have you checked your motor mounts?
Will a bad pitman arm make a noise on the passenger side??
