Sponsored by: CARiD
tire size?
Old Oct 7, 2005 | 12:15 PM
kmfdm242's Avatar
tire size?
I have a 97 f150 extended cab with stock suspension. I need new tires and would like to go as big as possible with out doing a lift. I am also going to go with the cheap black steel wagon wheels 15". I went to sams club and they had bf goodrich 33" and 35" tires? Would I possibly be able to fit the 35s on my truck?
Old Oct 7, 2005 | 12:20 PM
wilsonford's Avatar
i dont think you can run 15 in wheels 97 to 03needs atleast be 16's i might be wrong anyone else
Old Oct 7, 2005 | 12:26 PM
kmfdm242's Avatar
Why can't you run 15" rims?
Old Oct 7, 2005 | 02:05 PM
JackdUpSilvF150's Avatar
Brake clearance IIRC
Old Oct 7, 2005 | 03:44 PM
wandell's Avatar
Right, the brakes are too large for 15 inch wheels to fit over them. I would suggest staying with your OEM wheels and going with some 33's. 285/75-16 or 285/70-17 would be the best size. Both tires are 33x11.50's.
Old Oct 7, 2005 | 04:03 PM
kmfdm242's Avatar
The reason for changing my rims is that they are corroded from salt. It was a truck from Michigan. No chance at getting a bigger tire than 33".
Old Oct 7, 2005 | 04:10 PM
wandell's Avatar
If you use the OEM wheels, you can fit a 315/75-16 or 315/70-17 (35x12.50) by cranking up the torsion bars. This is an extremely tight fit and you will have some slight rubbing on the frame at full steering lock. Which factory wheel do you have?
Old Oct 7, 2005 | 06:34 PM
kmfdm242's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
I cant figure out how to make this a link that you can just click on, but my rims are the same as this one.
Old Oct 7, 2005 | 11:50 PM
17x7.5
265/70/17 is the stock size for that wheel....which is a 31.5x10.5 or thereabouts, IIRC
Old Oct 8, 2005 | 10:13 AM
wandell's Avatar
If they are corroded really badly, I would suggest beadblasting them and painting them. I think they would still look better than the black steel wheels, but I'm just not a fan of black wheels. If you want black wheels, you could just paint the OEM wheels black, but I think silver would look better personally.
