Sponsored by: CARiD
Installing daystar 2.5" level kit, need help!
Old Sep 13, 2005 | 04:05 PM
txs150's Avatar
I must be retarded, everyone says these are easy to install and i am having a heck of time with the upper ball joint. I am trying to install the leveling kit on me 04 screw and i am having trouble separating the the spindle from the upperball joint. I have tried using the air hammer with a ball joint remover but all i am doing is tearing up the rubber boot. Does anyone know how to do this? Thank you sooooo much for your help.
Old Sep 13, 2005 | 04:09 PM
wandell's Avatar
Most people use a hammer to seperate them because of this reason. Of course you need to do something to protect the threads.
Old Sep 13, 2005 | 04:34 PM
05supercrew's Avatar
I used a 5lbs sledge hammer but a regular hammer will do it with 2 shots.
Old Sep 13, 2005 | 06:44 PM
txs150's Avatar
thanks for the help , i got it off without any trouble, now i have the strut off an am having trouble compressing the coil, do you need two coil compressors? or can you do it with one? I have been trying with one but must be doing somwthing wrong because its not compressed enough and the tool is maxed out. any suggestions? thanks guys.
Old Sep 13, 2005 | 09:14 PM
Import-Tooner's Avatar
I had to use two. I put one on both sides. And, Make sure you get them even on both sides. like.. 180 degree's from each other. If you know what I mean. You want the spring to compress straight down or when you go to put it back together it will be a pain in the ***. Also, you have to have them hella compressed to get them back together when you have the spacer in or you won't be able to get that top nut on.
