Front lift
Originally Posted by wandell
The ride height of the 97-03 F-150's is adjustable by using the torsion bars. You can probably gain 2 inches of lift depending on where they are adjusted at now.
Rancho, Fabtech, Skyjacker, Superlift (just to name a few) all make a 4" kit. I'm not aware of anyone that makes a 3" suspension lift. You can, however, do a 3" body lift from any number of sources. If the only thing you're trying to do is get bigger tires stuffed in there, a body lift will work just fine for $150.
-Joe
