Sponsored by: CARiD
Steering column shaft loose!
Old Aug 2, 2005 | 08:54 PM
falcon's Avatar
My steering column shaft is loose and appears loose from both the steering box and the top part where it goes to the cab. I can grab is and there is play. I have a mechanic friend that can change it for me - the box is about $200, and if the shaft needs replaced I have to get that from Ford and I don't know how much that would cost.
I have been have vibration problems, though my my front end parts are all good. I Just got new tires and had them balanced twice. The vibration problems were around prior to the new tires.
My question is this: Is it likely that this problem (loose shaft) cause the vibrations I have been getting in the front end - especially at speeds above 40, and the worst being at speeds at 55-65 mph? My mechanic friend this this may be the cause, but he says it's about a 50/50 chance.
Thanks for the help,
Steve
Old Aug 2, 2005 | 09:06 PM
1Ford-Fan's Avatar
Hi Steve,
Where do you feel the vibration in the steering wheel or in the seat? Also do you feel the vibration all of the time or after hitting a bump? The worn steering shaft and steering gear box will more likely cause wandering issues. I would check and make sure none of the wheels or tires are out of round.
Old Aug 2, 2005 | 09:15 PM
falcon's Avatar
Thanks for the reply. I feel the vibration in the steering wheel, though there is a sense of the front end vibratring, not in the seat, but instead it just feels like a vibration in the front end only coming from the wheels. I have had passengers notice it and bring it up without me saying anything.
I just got new tires and had them balanced after 1,300 miles. No difference. The problem seems to be getting worse. I had the same trouble when I had my previous tires, and I thought it was better with the new tires, but it seems to be getting worse again. I really don't want to start putting money into fixing parts I know are wrong if I don't feel comfortable that the vibration will be fixed. I have done a search here and it seems vibration problems can be hard to find unless there is a know bad front end part. Or bad tires. I don't believe either applies to this case.
Old Aug 2, 2005 | 09:37 PM
metla's Avatar
My '01 Expedition is at the dealer right now for the same problem. It will be ready tomorrow, they had to get parts from across town. I'll post when I get it back to let everyone know what the problem was.
Old Aug 3, 2005 | 02:04 PM
metla's Avatar
Just picked up the truck and the Ford Dealership replaced the Steering Shaft and Idler Arm. Steers and rides like a dream.
Old Aug 3, 2005 | 03:26 PM
falcon's Avatar
Metla,
Other than a loose steering shaft, what other, if any, symptoms were you having? Were you haveing any vibration or loose feelings when you were driving?
Thanks,
Steve
Old Aug 3, 2005 | 08:58 PM
metla's Avatar
Only when I accelerated, braked or hit some roughness in the road did the steering column rattle. At high speeds there was no vibration or shaking.
