2006 Lift Kits?
Hi, All:
Any news on lift kits for the 2006 trucks, specifically the F250's? I imagine the coil spring front end is going to make the lifts a bit tougher to install.
Thanks in advance,
-Justyn
Thanks in advance,
-Justyn
The Super Duty trucks were redesigned in 2005. All the major manufacturers already have lift kits for them. The only question is how high do you want to go and how much you want to spend. The SD's still have a solid axle, so lift kit manufacturers had kits available pretty quick.
Didn't realize that - thanks! So the 8'' Fabtech kit below would work for my application?
http://www.fabtechmotorsports.com/html/ford4wd-sd.html
Thanks!
