Sponsored by: CARiD
Upper control arm.
Old Jul 22, 2005 | 12:50 AM
FunFord's Avatar
Registered User
Upper control arm.
I am replacing the upper control arm on my F150 ( not a Lightning). I dont have a torque wrench, so do I tighten the bolts all the down as tight as they will go, or just snug them up? The control arms are new so is there any kind of greese I need to put on the bushings before mounting the control arm? Thanks!
Old Jul 22, 2005 | 01:02 PM
FunFord's Avatar
Registered User
ttt
Old Jul 23, 2005 | 02:28 PM
Fritzthecat's Avatar
I used wheelbearing grease to coat the bolts and bushings. I torqued as hard as I could with my wrench. Since you are going to need an alignment anyway, the torque doesn't matter as the alignment guy/gal has to loosen them back up.
Fritz
Old Jul 24, 2005 | 11:18 PM
ruffn-it's Avatar
Fritz
Agreed, But if you work on your truck a lot you might want to think about buying a torque wrench.
