Sponsored by: CARiD
Installing pinion shim?
Old Jul 20, 2005 | 05:32 AM
NORCALSTI's Avatar
99 f150 lowered 3/4 shackes and hanger in back
now if i get a 4 degree shim do i just put the truck on stands jack up rear end, unloosn the u bolts and slowly let the axle down so i have space to slap in the shim??? then jack up axle line it up and tighten it down or does the shim go between the acutal leafs?
do i need a longer bolt to go threw the leafs?
anyhelp is apprecaited
Old Jul 20, 2005 | 02:44 PM
bigtruck311's Avatar
it goes in between the axle tube and the leaf spring pack, make sure you put it in the right way, good luck
