Hotchkis TVS Suspension Kit Install
I'll be installing a Hotchkis TVS Suspension Kit on my '04 Lightning this weekend and would like to know if anyone out there has instructions on installing the springs.
Hotchkis includes instructions of how to install the sway bars but not the springs. When I called Hotchkis I was told they don't include instructions for the springs because a spring compressor is needed and there is risk involved. Hotchkis must feel they have some legal exposure and are not willing to take the chance.
I've installed lowering springs on an 'O1 Mustang Cobra without a problem.
Can anyone offer advice as to what issues I might run into?
I've purchased the cam bolts and washers from Ford that attach the a-arms to the frame. I understand this provides additional adjustment for the alignment shop.
Thanks,
cobralight
Thanks,
cobralight
install
on mine i just supported the truck w/jack stands and jacked up the lower control arm to compress the spring. then i removed the two upper control arm bolts and slowly and i mean slowly lower the jack until the spring is loose. you might need cam kit but not sure on the lightning. hope this helps....
