Sponsored by: CARiD
Rear Shocks
Old May 27, 2005 | 03:10 PM
MIRLIN's Avatar
Rear Shocks
ok this is my first ford bought it new 2002 F150 S/C the driver side rear shock is there a bolt and nut that goes the fram?
Old May 27, 2005 | 04:35 PM
iron horse's Avatar
Rear Lower shock mount = bolt through bracket, then through shock bushing, then through other side of bracket, then nut.
Rear Upper shock mount = bushing washer under frame, then bushing under frame, then over frame bushing, then washer, then nut
Old May 27, 2005 | 09:38 PM
MIRLIN's Avatar
I have :bushing washer under frame, then thats it no bolt stud and bolt the stock one had to of broke off F!!*%$%$%@ oooops what would be a good atermarket replacement it's stock height and i tow a boat ?
Old May 27, 2005 | 11:57 PM
iron horse's Avatar
So your talking about the TOP mount for the rear shock?
So you do not have a bolt sticking out of the top of your shock?
So the top of your shock is not bolted down to the frame?
Old May 30, 2005 | 09:08 PM
MIRLIN's Avatar
Found it the top bolt snaped off
