Sponsored by: CARiD
Hit a curb, possible damage?
Old May 9, 2005 | 10:28 AM
01Lightning's Avatar
I hit a concrete curb head on a few days ago... destroyed the front 2 tires and wheels. Nothing under the truck seems to be damaged, but I have not had a chance to drive it yet, waiting on new wheels and tires. Also, the bed seems to have been shifted slightly. It actually contacted the cab on the pass side, putting a small dent in the cab. Can the bed be re-aligned by loosening the bed bolts and repositioning? I appreciate any advice you guys can give!
Old May 9, 2005 | 12:52 PM
wandell's Avatar
Yes, that is how you would realign the bed. If you hit a curb that hard, you probably have some damage to the front end. At the very least the alignment was knocked out of whack.
Old May 9, 2005 | 02:08 PM
Do you think it is possible that the frame was bent causing the bed to be knocked out of alignment?
Old May 9, 2005 | 03:41 PM
bigtruck311's Avatar
you would have to hit the curb realy realy hard to bend the frame, i dont think it was hurt but you can take it to a colision center and they can check to make sure your frame is straight, good luck, i think it would have bent suspension components before it would bend frame
