Sponsored by: CARiD
lift height??
Old May 4, 2005 | 05:33 PM
CANADIAN_f150's Avatar
lift height??
I have a 2001 f150, just did a 3 inch body lift, i had 33"s on before and im putting bigger rimms and tires on now, can i fit 37X12.5"s if i get the keys for the torsion bars and move them up 2 inch"s, and put 2" blocks in the rear with new u bolts?
Old May 4, 2005 | 05:59 PM
bigtruck311's Avatar
i dont think that you could fit a 37" with a body lift and 2" more lift i have around 11" of lift total on mine and 38" 15.5 barely fit and had to do alot of triming in numerous areas to clear them with no rub, i dont recomend getting the recast torsion keys and maxing them out this causes a severe angle on the front halfshafts and will cause premiture wear and binding in 4 wheel drive if you want to clear that large a tire your best bet would be to save up for a 6" lift, sorry to be all bad news but good luck in your decesion
Old May 4, 2005 | 07:31 PM
All right thanx man, ill stick with the 35X 12.5 BFG mudderz than, thanks for the tip man,, when i put em on ill have a new pict to post...
Old May 4, 2005 | 08:12 PM
good luck hope the 35" fit nice with no rubbing
Old May 4, 2005 | 10:19 PM
wandell's Avatar
I agree with Bigtruck311.
