Fabtech Spindle Lift
I am going to get the 3.5" Fabtech Spindle lift for my 2001 f-150 2wd, but i was wondering if the daystar leveling kit still works with the fabtech lift? if it does then i will get a 3" block in the back to it will be level with the front. thanks for any info
Yes, you can add a Daystar spacer with the Fabtech spindles. You will probably have to buy one of the adjustable camber kits to get you front end aligned correctly however. I think they are around $40 or $50 from NAPA.
