Sponsored by: CARiD
Fabtech or Skyjacker
Old Apr 11, 2005 | 08:38 PM
Nahdizzle's Avatar
Ok, so I know this probably has been asked before, but which is the better lift kit? I want to do a 6 inch lift and maybe a body lift after that. And if which ever lift I go with, what else should I be expected to purchase?
Thanks for any info!
Old Apr 11, 2005 | 08:40 PM
pj4553's Avatar
i hear so many good things about fabtech!!
Old Apr 12, 2005 | 07:55 AM
wandell's Avatar
I think the Fabtech is a little better. If you add a body lift, you will want to get a set of Gap Guards to cover the gap in the wheelwells that the body lift creates. Also, you obviously want a really big tire if you want 9 inches of lift, so plan on regearing also.
Old Apr 12, 2005 | 09:06 AM
MaroonBaboon97's Avatar
I agree
I agree with Wandell.. one of my buddies has a 6 in Fabtech Suspension lift with a performance body lift.. and it looks really big....he's also running 38s on it so if you do get the Lift get some bigger tires
Old Apr 12, 2005 | 10:05 AM
bigtruck311's Avatar
fabtech all the way, i love mine
Old Apr 12, 2005 | 01:49 PM
JackdUpSilvF150's Avatar
When I bought my lift, SuperLift was the only supplier I could find at that time. I have the Superlift 4.5-5", PA 3" body lift on my 2000 F150: 4.56 ratios and 37x13x16 Boggers.
The SuperLift steering knuckles seem to require that you run a large offset/shallow backspace wheel to get anything wider than a 12.50" on there.
The Fabtech knuckles look like they're "cut back" further, and bigtruck311 is running a 15.50". I'm curious what the backspace and offset of bigtruck311's wheels are.
With my setup and the SuperLift knuckles, the 37x13x16 bogger rubs (well, clunks ) a lot at full lock...I'm probably backing down to a 35-36"x12.50" when the Boggers finally wear out so I don't rattle anyone's fillings out again.
Jack
EDIT: found it!
bigtruck311
i have about an inch with 4.5 of backspacing on 16"-10" rims with the mods below (see bigtruck311's mod list above ^)
I'm thinking I should have waited for the fabtech...first to market does'nt mean best to market.
Old Apr 12, 2005 | 02:29 PM
Southern-Fx4's Avatar
I have the fabtech and love everything about it. Great ride and great looks. I highly reccomend it. I can post pics if you need.
Old Apr 12, 2005 | 03:55 PM
Nahdizzle's Avatar
That would be great, any pictures or tips to installation would be great!
Thanks all.
Old Apr 13, 2005 | 06:50 PM
check out my gallery for more.
https://www.f150online.com/galleries....cfm?gnum=5448
Old Apr 19, 2005 | 09:37 PM
SoTxFx4's Avatar
I'm looking into getting the 6in. Fabtech kit for my truck. It looks a high quality suspension system. What kind of gears will I need for a S-crew with a 5.4 running 35's? Thanks
Old Apr 20, 2005 | 10:13 AM
4.56 to get close to stock
