Sponsored by: CARiD
differences in a Fabtech 7.5" lift
Old Apr 8, 2005 | 10:03 PM
cookiemonster45's Avatar
I was looking on the Fabtech website for a F150 2wd lift. I saw that theree is a 7.5" performance cossmember system, and a 7.5" Ultimate Long Travel System. I was wondering what the difference was between the both of them. Also I was wondering if I can add a body lift to either one. Any information is appreciated..
Old Apr 9, 2005 | 12:20 AM
porky's Avatar
from what i understand, the crossmember system uses just that, a new lower crossmember in order to use the same lower control arms, just positioned lower. The long travel system uses all new longer upper and lower control arms, i think, please correct me if i am wrong anyone.
I do know for a fact that you can put body lifts with both of these kits, in fact, body lifts fit with all types of suspension, either stock or lifted, b/c they have nothing to do with the suspension itself, they just raise the body off the frame.
Old Apr 9, 2005 | 12:36 AM
thanks alot for the info. So both systems will give me exactly the same height? if so, why are there 2 kits?
Old Apr 9, 2005 | 09:12 AM
Johngs's Avatar
Because they lift with different methods. The reason for that, Im not sure, but if I had to guess, I would say its so that buyers can use multiple lifts and achieve more total lift.
Old Apr 29, 2005 | 01:27 PM
f150tucson's Avatar
The difference between these two lifts is the suspension travel. I just emailed Fabtech and asked about there long travel kit and the said it adds 4-7 inches of suspension travel to stock which would be better off roading. The cross member lift just simply makes the truck taller.
f150tucson's Avatar
Old May 12, 2005 | 11:18 PM
Redf150-2wd's Avatar
im about to put the 7.5" fabtech on mine and its already got the 3" body lift on there.....runnin that thing on 37"s
ill post pics when i get it all done......if i ever figure out how to put pics in here
Old May 13, 2005 | 11:25 AM
Offroadfvr's Avatar
The long travel kit has upper and lower control arms with new tie rod extenders. It extends ur wheel base a little furthure which means to get full performance you need fiberglass fenders. The kit is hard on ball-joints; get the lifetime warranty Napa ones. The other kit is upper arms coils and spindles, just like the other kit, but with less usable travel.
Old May 13, 2005 | 05:16 PM
tlw59's Avatar
We put the 7.5" long travel kit on a 1999 F150 along with a 3" body lift kit and aside from this great desire to add motor home steps, have found it really serves our off roading purposes very well. Aside from the lift combo and 38" Super Swampers, the Mastercraft suspension seats have been best adds we've done! Sure saves the on the punishment on the bod!
Old May 13, 2005 | 05:21 PM
f150tucson's Avatar
Hey TLW59, your truck looks great. Do you have anymore pics?
Old May 13, 2005 | 05:31 PM
tlw59's Avatar
Thanks. Only problem with the look it the "looks" it gets from members of law enforcement! hah-hah If I could find peel and stick window tint I'd save a fortune! hah-hah
Old May 13, 2005 | 05:36 PM
f150tucson's Avatar
TLW59, how does that suspension handle if your haulin but over a bumpy dirt road?
Old May 13, 2005 | 05:52 PM
tlw59's Avatar
Coupled with the suspension seats I've gone over a 2' road berm at over 60mph and hardly noticed it. I talked with a Fabtech engineer who lives in my area, about putting on a prototype coil over suspension, but even at his/Fabtech's "cost" I might have to rob a bank! hah-hah, but it sure would
be trick! On the road I notice the ride from the tires, both sound and feel but while not a sports car, it handles the curves pretty well.
Old May 13, 2005 | 05:57 PM
tlw59's Avatar
Cookie, the only problem I've had was the right front axle sheered off the spindle! I talked with Fabtech and they wanted the spindle back, big time(Kept asking if anyone was hurt! heh-heh) Luckily I was on the old road by Magic Mountain and the spindle ground into the pavement and stopped me, since the axle, brake assembly and right front wheel and tire had shot across all lanes of traffic at 55mph! (amazing isn't it that when the right front brake line gets snapped you can't stop! heh-heh) Found the wheel and tire the next day several hundred yards away. Thank goodness no one was hurt!
Old May 13, 2005 | 06:04 PM
f150tucson's Avatar
I saw a picture of a Fabtech coil over kit on a 97-03 f150 from a sema show. It looked so cool. Thanks for the info. I can't wait to get my Fabtech lift and cause some dust in the desert.
