Sponsored by: CARiD
Suspension Lift for a 2001 F-150 2wd
Old Apr 3, 2005 | 08:09 PM
SilverBF150's Avatar
Alright after much debate, I am going to bite the bullet and get a suspension lift. I really want my truck lifted and I looked at body lifts, but with the install price i might as well get a suspension lift.
I just need some info... where to buy, how much i can expect to pay.
I want to lift it 4" and I have about 400 - $600 to spend (thats hopefully including install)
What do you guys recomend I get, or look for?
Old Apr 3, 2005 | 08:58 PM
breaker's Avatar
I think you should thinking body lift for that price.
Cheapest ive ever seen a 4 inch suspension lift was made by Rancho and it was 1400.00
Plus labor will be huge if you dont do it yourself its at least an all day project.
Old Apr 3, 2005 | 09:36 PM
noirluispher's Avatar
Yeah, you need to increase your budget for a suspension lift. Here is a before and after with a 6" Fabtech. DIYer.
Good look!
Old Apr 4, 2005 | 06:44 PM
ruffn-it's Avatar
you could try a fabtech spindle for 3.5in of lift and then a coil spacer for another 1.5in 5in total. Then put some blocks and/or add a leaf in back. That will run you about $800 (usually including new shocks).
Of course then you have to add installation, alignmnet cam kits and an alignment.
Another option is get the 3in body lift and then you could add the coil spacer for about 4.5in of lift in front and then blocks in back. This would probably be cheaper.
Good Luck
