Sponsored by: CARiD
after leveling kit.... alignment needed?
Old Mar 30, 2005 | 09:24 PM
gotnoboundry's Avatar
just got a 2.5" leveling kit done to my 2004 supercrew lariat. it's a 2x4, but i've noticed since driving out of the shop, a difference in turning (stiff at times, then loose at times) and it just doesn't feel right. do i need an alignment done? will that fix that prob?
also feel like at higher speeds i have lost power. is that due to the front end taking on more wind resistance? or will an alignment fix that?
any help would be appreciated.
also wondering can i pick up the 2" lift block from a 2004 4x4 with longer u-bolts and hook it up to my 2x4 to lift up the back some more?
thanks!!!!!
Old Mar 30, 2005 | 10:05 PM
wandell's Avatar
Yes, you need an alignment. As for the lift blocks, I'd just get a set of aftermarket lift blocks and u-bolts. They will be a lot cheaper than the Ford pieces.
Old Mar 30, 2005 | 11:00 PM
thanks wandell!
you are the man!
always pleasant with the posts. i realized my questions had been asked before, and thought i might get slammed... but just the opposite.
God bless.
