Sponsored by: CARiD
steering noise please help
Old Mar 11, 2005 | 10:24 AM
breaker's Avatar
I have a 98 f150 4x4 and have a really bad non mechanical noise most prominant when i turn the wheel. Im pretty sure its not mechanical cause I can be parked and when i turn the wheel its this loud squeaking/creaking noise. I can also hear it if I stand on the drivers side running board and bounce up and down. But mostly it happens when I turn the wheel. Any ideas? Im stumped.
Old Mar 12, 2005 | 11:14 PM
1Ford-Fan's Avatar
Check the steering linkage while someone turns the wheel. Check the pitman arm and the tie rod ends. You can also try and pivot the tie rod assembly with a wrench and find the noise (if it is a tie rod end). It should be easy enough to to find the one making the noise. You may also be able to feel the one making the noise(vibrates while creaking). I hope this helps.
Old Mar 17, 2005 | 03:52 PM
breaker's Avatar
Not being mechanically inclined, how serious is this problem? i have a 10 hour drive coming up fast, can she survive or is the truck going to fall apart?
