Lifting The Rear Up
Lifting The Rear Up
HEY GUYS A BOUGHT A 2004 XLT 4X2 AND LIKE TO LIFT THE BACK UP 2-3 INCHS LIKE THE 4X4 ,NOTICED THAT THE 4X4 HAS A SPACER IN BETWEEN THE LEAFSPRINGS AND REAR END WHICH IS 2-3 THICK IF I PUT THEM ON MY 4X2 WILL THEY BOLT RIGHT UP AND WILL THEY GIVE ME 2-3 INCHS THEY ARE $75 BUCKS DOWN HERE AT THE LOCAL FORD DEALER THANKS
Yup just get a 2 or 3 in block for the rear, and make sure you get new longer u bolts. You could also get a add-a-leaf for about 1 1/2 to 2in.
I have both a 2in block and add a leaf on my 2x4.
Just keep in mind the back of your truck will set a lot higher than the front. You may want a coil spring spacer to lift the front another 1 1/2in.
Hey I also noticed that there is two bolts or studs through the factory spacer, what does that do? can I eleminate them?I am doing two inch leveling kit to the front at the same time. Does the factory steel two inch spacer off the 4x4 have the holes for the studs? or can I just make up something? Thanks again for your help..
