Sponsored by: CARiD
body lift
Old Feb 18, 2005 | 02:07 PM
00F1504x4FL's Avatar
body lift
I know there are a million threads about body lifts but i cant find this discussed anywhere. I have installed a body lift before and i had to notch out my floor board for my 4x4 shifter. The shifter on my scab is also on the floor. Am I gonna have to notch it out? Aslo on the regualr column shiffter do i have to get a section welded on to extend it? I had to do that on my last one. One last question. does the regular PA kit come with the rear bumper bracket or do i have to buy a seperate kit to raise the bumpers? sorry if these are repeated questions from old posts i jst couldnt find the answers. thanks.
Old Feb 18, 2005 | 03:38 PM
wandell's Avatar
I don't know about the floor mounted transfer case shifter as mine has the dash mounted ****. The 3 inch PA kit comes complete with a steering extension and front and rear bumper relocation brackets. The only thing extra you need to buy is a set of PA's Gap Guards.
Old Feb 18, 2005 | 04:36 PM
thanks, i will be sure to buy the gap guards. anyone else know about the shifter on the floor? i really dont want to cut up my floor boards like i did on my blazer.
Old Feb 18, 2005 | 10:00 PM
dandwg's Avatar
I want to see a pic of your blazer
Old Feb 18, 2005 | 10:05 PM
bamacpl's Avatar
I may be cheap....but instead of buying PA gap guards I went to Home Depot & bought basically the same thing & cut it to match. I have had the gap guards & this is basically the same thing! & it lasts just as long!
Old Feb 18, 2005 | 11:29 PM
sorry. it wasnt a k5 it was an s10 blazer 4x4. had 2in suspension 3 in body and 35's. it did pretty good for being a grocery getter, i wish that i had a k5. i would still have it. and i made my own gap gaurds for the blazer. i just dont have too much time on my hands right now for any fabrication (even little stuff)
Old Feb 21, 2005 | 03:15 PM
JackdUpSilvF150's Avatar
body lift / Transfer case shifter lever on floor
What we did works well, but requires a welder.
I had the 4wd shift lever cut in about half then welded in an extension piece for it. I think we had to slightly re-angle it to fit properly in the old floor hole, that's about it.
