Sponsored by: CARiD
99 F-150 gears and suspension
Old Feb 8, 2005 | 01:20 AM
Mxtweeter2000's Avatar
Question 99 F-150 gears and suspension
Just a couple of question. I have a 1999 F-150 that has a 6" Fabtech suspension, and a 3" body. After all that good stuff I wanted it just a little higher. So I added another block in the rear and adjusted the torsion bars. I have had a couple of problems. I have 17" wheels with 37" x 13.50 and for some reason just the driver front wheel has become a pain. The lug nuts have been popping off like crazy. I have heard two different things to do. 1) Torque the wheels 2) adjust the torsion back. But I have heard a more interesting one. Get reversed threaded lugs so they will tighten while driving. Since I did all that I was wondering what kind of gears to put in it also. Right now it is stock with 3.55.
Old Feb 8, 2005 | 11:01 AM
max mitchell's Avatar
Welcome ! I'll comment on the gears only. You're going to need 4.88s to even get near the stock setup with 37s.
Old Feb 8, 2005 | 11:26 AM
bigtruck311's Avatar
that is very weird that the lug nuts came off mine have never even losened, i dont think it will hapen if you torqe them down to specks or you could try getting a difrent set of lugnuts that culd be the problem also, or you could put a small amount of locktight, on the gears i would go with 4.88 or 4.56 i would recomend 4.88 in my opinion
Old Feb 8, 2005 | 11:55 AM
Question
Thanx guys. yeah I have had to put some time in this truck. Every inch of it I have done myself. But so far the lug nuts are good. I had another question about the drive shaft. It is atleast two inch in the transmission, is that enough? Also has anybodies four wheel drive keep poping inn and out? I know its because of the lift but how to fix it?
Old Feb 9, 2005 | 12:54 PM
brahmus's Avatar
First: 4.56 are easy to get 4.88 are/were on backorder nationally because they are newer. but 4.88s are better. Next are the studs breaking or the nuts backing off. third get a 6degree procomp shim from summit. it will put less stress on the u joints and put more of the drive shaft into the tranny. four, get some traction/ladder bars and that will limit your axle from moving and pulling the driveshaft out.
my $.02
