Installing shocks
Installing shocks
My roommate gave me his stock shocks from his 03 f150-hd. His new ones came compressed and had to remove something once installed. Is there anyway to install the used shocks on my truck without having to compress them? Is there any easy way to compress them?
Installing them on a 97 F-150
Thanks in advance.
Thanks in advance.
Yup, the compression bands don't make a huge difference anyway. You need jackstands as well as a jack. Raise up the truck and put a jackstand under the frame so the axle hangs, then use the jack to raise and lower the axle for your install.
Remove the lower shock bolt first, then the upper. On install, attach the upper first and then the lower.
