Sponsored by: CARiD
Budget boosts???
Old Jan 11, 2005 | 11:14 PM
The Mule's Avatar
Budget boosts???
New wrench head around here.
I have a question about doing some minor lifting on my truck...
I dont want to put a BL kit on there, but I do want a little lift out of the suspension. What are my options?
Cranking torsion bars?? Need all the info ya'll got on that one!
Do they make spacers for the front for these things???
Will do Add-a-leaf on the rear. Who all makes them??? Full length, shorties, what???
I have a Jeep and have done alot of lifting and fab work on it, and now I am moving over to the "Mule"(truck) which is the one that pulls the Jeep(trailer queen) around.
This is a neat site and I need ya'lls help on this please, because as of now I am only good with leaf sprung, solid axle suspension!
IFS make me nervous...
Old Jan 12, 2005 | 07:56 AM
wandell's Avatar
As for lifting the front your options are cranking up the torsion bars or a full suspension lift. You can usually get 1 to 2 inches of lift by cranking up the torsion bars. Don't forget to get the front end aligned afterwards.
Old Jan 12, 2005 | 09:58 AM
brahmus's Avatar
pro comp add-a-leafs from summit $42. good for 1.5 to 2"s.
Old Jan 12, 2005 | 09:04 PM
The Mule's Avatar
Any side effects to cranking the torsion bars???
Is there a proper way other than taking the weight off the front end and cranking down on them?
Is there a limit???
Add-a-leafs, are they shorties, or full length???
Old Jan 12, 2005 | 10:24 PM
wandell's Avatar
Cranking up the torsion bars will make the initial portion of your suspension travel stiffer. Some people love the ride, some hate it. I suggest trying for yourself. The add-a-leaves will also stiffen the ride.
Old Jan 13, 2005 | 08:28 AM
brahmus's Avatar
i believe the pro comps i got were long leaves. why? Or Blocks in the rear.
Old Jan 13, 2005 | 07:03 PM
The Mule's Avatar
Long leafs give a better ride than the short one's...
Don't wont blocks because I could use the extra hauling capacity.
Still not sure about cranking the torsion bars... Waiting for someone to give some insight on my questions above.
Old Jan 14, 2005 | 08:37 AM
brahmus's Avatar
As far as i know you can bottom out both bolts with no problems other than the ride quality! And i guess i'd consider proper to be, remove weight, tighten bolts,remove jack, check height left and right, adjust as nessecary, Enjoy!
Old Jan 16, 2005 | 12:01 AM
The Mule's Avatar
Well, I appreciate all the info and I am about to embark on this little journey...
One more question...
Any reason why the Add-A-Leaf kits DONT come with spring clamps???
Old Jan 17, 2005 | 08:31 AM
brahmus's Avatar
My pro-comps DID!
Old Jan 17, 2005 | 09:05 PM
The Mule's Avatar
Great! They just didn't list them in the description... I will order some tomorrow!
Old Jan 17, 2005 | 09:07 PM
The Mule's Avatar
