Sponsored by: CARiD
front lift
Old Dec 29, 2004 | 11:38 PM
Basebal287's Avatar
front lift
I currently drive a 2003 F150 Xlt 2wd super cab, and i currently put on 285's 75R16 and there is hardly any clearance. I dont wanna take it off road or over any bumps with this little clearance? I want to get a 1 or 2 inch lift in the front to fix this problem and it will also level out the truck. I wanna do this and spent the least amount money possible for this? Anyone have a idea that i can accomplish this without spending much money whether its just blocks or whatever? If someone does have a idea do u reccomdend a 1 or 2 inch lift. I dont want it to be a upward position also just want it level. Any help appreciated thanks bill
Old Dec 30, 2004 | 08:20 AM
wandell's Avatar
Get some Daystar coil spring spacers.
Old Dec 30, 2004 | 10:42 AM
Basebal287's Avatar
LIFT
Well if i get those how much will that cost to get and install, also how much higer do u think i should get in the fron tto level it off with a 2wd truck?
Old Dec 30, 2004 | 11:54 AM
jpony645's Avatar
http://www.4wheelparts.com/4wp/produ...ension&man=DAY
Cheapest I've found so far. Then you'll need a front end alignment.
I just measured my 2003 xlt reg. cab this morning and sits 35 3/4" in the rear and 32 1/4" in the front. 2" spacers will still leave you about an inch lower in front but that's as high as you can go without changing the upper control arms.
Old Dec 30, 2004 | 03:38 PM
wandell's Avatar
I agree.
