Sponsored by: CARiD
Body Lift + A Leaf + Torsion
Old Dec 27, 2004 | 03:09 PM
pasian4life's Avatar
To Wandell and anyone else:
I put a 3" body lift, add-a-leaf in the rear, and cranked the torsion bars on a 98 ford f150 4x4 ..... Should I put new shocks on this truck or does it matter??? If so, which ones.... extended or standard?
I got a good 2" on the torsion after it settled.... and that's all the way.... Is this a bad idea?????
I am putting 35's with 17x9 on the truck!
Thanks, Scott
Old Dec 27, 2004 | 03:55 PM
wandell's Avatar
New shocks are never a bad idea, but they are not necessary. You do not need longer shocks if you do replace them.
Old Dec 28, 2004 | 08:32 AM
Summit Racing is sending me pro comp shocks es3000 that show a fitament for 2-4 inches lift.... That is what the tech dept. said would fit.
Should I be buying stock height shocks??
Also, can the front end be aligned with the torsion cranked all the way 2"??
Thanks Wandell
Old Dec 28, 2004 | 10:48 AM
bigtruck311's Avatar
yes you need to get the front end ailianed after cranking the torsoin bars
