2002 f150 2WD coil spring spacer kit
Ok Ive read the last 30 days of threads and posts. Im trying to do my research on 2WD lifts, any other input would geatly appreciated.So far i found that Daystar has a 1-1/2 and 2-1/2 coil spring spacer kit. On the 2-1/2 it says requires after market control arms, not sure if i want to get this involved,how hard is it to change them out,and what do they cost. What about any other suspension parts,linkages, brake line, shocks, ect.. Now the 1-1/2 doesnt say it requires anything.Does anybody know if this is true.Depending on which coil spring kit i go with will determine what size blocks and U-bolts ill need 1" or 2" in the rear.
2002 F150 XLT Extcab 4.6 2WD
I believe if you lift the front over 2 or 2.5 inches you have to have new upper control arms or you can't get the alignment right on the front end. With the smaller spacer you may or maynot need a camber adjustment kit, which is around $40 or $50.
Thanks Wandell Iwas hoping you would answer my Post.I have decided to go with the 1-1/2" spacer kit due with future problem that may come up if i go over 1-1/2".Now on this camber adjustment kit is this something that is going to come up when i go get an alignment or is this something im going to have to figure out on my own. Does any body know the best place to buy these kits 1)Daystar 1-1/2" 2WD front coil spacers
2) 1" rear leaf spring blocks 2-1/2" wide
3) U-bolts 3-1/4" x 8-1/2" x 9/16" thread
Thanks again
Thanks again
