Sponsored by: CARiD
Torsion Bars
Old Nov 5, 2004 | 11:06 AM
bonefish's Avatar
Torsion Bars
I have been told that you need to jack the front end of your truck off the ground before you crank the torsion bars up. Is this true or not?
Old Nov 5, 2004 | 11:55 AM
DEZEL73's Avatar
I adjusted mine without jacking it after each turn I would pull the truck back then pull forward before measuring to make sure they had settled. I hear the bolts turn easier if it is off the ground though.
Old Nov 8, 2004 | 03:27 AM
way fast witey's Avatar
that's true.if you do it on the ground,i hope you have a good impact cause it gets a little tiring crankin on those bolts underneath the truck.but it can be done
Old Nov 8, 2004 | 07:47 AM
DEZEL73's Avatar
I just used a half inch drive breaker bar worked fine.
Old Nov 11, 2004 | 02:57 PM
i did a friend of mine's with a 3/8 ratchet cause my 1/2" was broken at the time and it sucked.i just remembered that,so yeah as long as you have somethin bigger than that its fine
Old Nov 11, 2004 | 05:18 PM
BigSteve1's Avatar
I just did mine 15 minutes ago with a 1/2" ratchet and couldn't believe how easy they turned. Shot them with some break-free, let it sit 10 minutes and turned them.
