turn torsion bars?
I have a '03 supercrew 4x4, what size of tires will i be able to run just by turning up the torsion bars? i do not want to have to do any trimming. is it safe to turn up the torsion bars? will the truck handle different? thanks for the help!
Just lift the front of the truck off the ground and turn the adjustment bolt in a turn at the time untill you get the height you want. Just make sure to turn each adjustmnt bolt the same number of turns.
https://www.f150online.com/galleries...889-103342.jpg
Most 285/75-16's and 285/70-17's are just a hair shy of 33 inches tall, or right at 33 inches tall. Essentially they are 33x11.50's. The exact height can be found on the website of the particular tire you are looking at.
Originally posted by gerrys2
Thanks for the info. I'm going to raise it this weekend and order my new tires. 285x70x17 hanks for replying
I also want to get a set of 285*70*17 for my stock 17's. What tires are you getting? How much are they?
If you can please post some pics and let me know how the torsion bar adjustment went. I plan on adjusting mine too when I get the tires.
I too plan to adjust my torsion bars. By the look of the pic you posted, the bolt to turn looks like a 3/4" or so bolt. Since I have never done this before I may sound like a DA for asking, but her it goes anyway:
I suspect you just turn the bolt either clockwise or counter to gain height. But by the looks of the bolt length, how much gain is actually possible? From the looks of it would you say a gain of 1/2 to 3/4 inch?
thanks !
Oh one more thing, if the front end is raised, what about the back? If the front is raised will it look taller than the back?
I fit 33x12.50x17 MT Baja MTX tires under my 01 Supercab 4x4 with no lift or torsion bar crank. In fact I there is about 2" clearence from my fron valance. The torsion bar adj. screw is 18mm, I suggest having a 1/2 drive ratch with a long handle has it it hard to turn. Remeber to mark the bolt so you can count the number of turns.
Every truck is set a little different. You can usually gain 1 to 2 inches of lift. Most people do this to level the front with the rear. If you want to raise the rear, install a taller lift block or add-a-leaf.
