F250LD torsion bars
F250LD torsion bars
I have read someplace that the F250LD torsion bars are the same as the F150 torsions bars that come with the 4x4 off road pkg. Can anyone verify this? Cant seem to find the original article.
Thanks for the help,
Rich
Rich
Re: F250LD torsion bars
Rich
Rich
robert
The F-250/7700 torsion bars will fit a F-150. They are stiffer than the standard 1/2 ton torsion bars. I think they would be a good upgrade if you are installing a heavy accessory on the front of your truck, like the Ranch Hand bumper or a heavy winch.
brahmus....yes that is what I thought too. The non 7700 f150 with the 4x4 and off road pkg has the same torsion bars that the f250 light duty and f150 7700 have. I know that the 7700/f250ld torsion bars are 1.36 inches in diameter. The 6500# torsion bars are about 1.27 or something. I just need a reliable whay of measuring mine.
Well I went outside today and measured. My front GAWR is 3600 lbs. I wrapped a piece of paper around the bar and marked it. I calculated the diameter to be 1.30 inches which is correct for the 3600 lbs on the front end. The 7700 f150 torsion bars diameter is 1.36. Does anyone know where the part numbers for these are? I found what was left of a yellow sticker on one. One part said "Made in Mexico" and above that was F56A.
Just moving it to the top and wondering if anybody found out if the 7700# t-bars will work.
John
John
From what I've read, the 7700/ F-250 torsion bars are different (stiffer) than any of the torsion bars that are used on any F-150 4x4. If you have a Supercrew, you will have to relocate the torsion bar crossmember further back. The Screws use a shorter torion bar than the other trucks apparantly. The holes are already in the frame, it's just a matter of removing and relocating the crossmember. A member at FTW did this on his Screw. I believe the 7700/F-250 bars are a direct bolt on for standard and Supercab trucks.
My point is that I would feel more comfortable tightening up the heavy duty bars over the regular ones. I think that there would be less of a chance breaking one of those. I am going to the a dearship to pick up some parts I ordered, there is supposedly a suspension expert that has been wit ford for 25 years. I will post any comments he might have later on.
Rich
Rich
