Sponsored by: CARiD
A little bit of lift and need some help
Old Sep 13, 2004 | 07:41 PM
250RRider's Avatar
Im looking to lift my 2000 F-150 supercab with a body lift and want to install it myself. I know a little about cars but dont know whats all involved with a body lift because one guy told me i would need to know a lot but one said its not hard. I was wondering what else besides the spacers and bolts i would need to do. Also with the 17 rims what is the best size tires with goodyear wrangler mtr's any help would be appreciated. thanks
Old Sep 13, 2004 | 08:39 PM
zski128's Avatar
I took looked at the MTRs, IF you do mostly on road driving i would not recommend them since they wear quickly for such an expensive tire. I think they only make them in a 285/70 which is about 32.5 inches. THese are probably the biggest you can go with no lift. In the end I picked the MT Baja Radials, great tire and is also a 6 ply! They are heavier than the OEM 265s, but I have not noticed that much of a MPG difference.
As for a body lift, I have no first hand experience, but I have heard that it a lot of work, you have to extend the the fuel filler pipe and mess with the steering, have to take up the rug inside and I think you may alos have to remove the rear seats since you have a super cab.
Old Sep 14, 2004 | 08:01 AM
wandell's Avatar
A body lift is not that hard to install. It's just time consuming and tedious. Most of it is pretty straightforward.
Old Sep 14, 2004 | 11:34 AM
bigtruck311's Avatar
it just takes alot of time,you have to do some drilleing on the bumpers, the feul fille neck is a pain to put the tube in and if you do any offroading i would get a longer hose instead, in the scab getting the seat out in the back is a pain and getting under the carpet is even worse, i ended up cutting my carpet with a razor just enough to get the bolt threw cuase it was pissing me off
