Sponsored by: CARiD
2" Coil Lift R & R Info. Needed....
Old Sep 3, 2004 | 07:12 PM
OE812's Avatar
I bought a Moog 2" Coil Lift from NAPA today with NAPA Gas Shocks for my 2000 F150 Supercab. I need the steps on removing the coils. Will I need a concentric cam bolt for alignment since I am raising the front 2"? If so, tell me the degree cam to buy.
Thanks,
Jeff
Old Sep 3, 2004 | 11:06 PM
Fritzthecat's Avatar
I used the NAPA cam bolt kit. No problems aligning with a 1.5in lift.
The easiest way to r&r the coilsprings (alignment required):
-Jack up truck and put on stands (as high as possible)
-rem both front wheels
-unbolt front swaybar from both sides and swing out of the way
-unbolt brakeline clip from bottom A arm
-rem shock (jack under bottom A arm to make this easier)
-put jack as far outside as possible under bottom A arm and relieve weight
-rem top A arm bolts
-lower jack until A arm is all the way down, watch out for brakeline
-pull out coil spring
-install new coil spring, make sure you align to the holes
-jack up bottom A arm until top A arm lines up with cam bolt holes, watch for the coil spring popping out
-install new cam bolts (best guess on alignment)
-remove jack
-install brakeline clip and shock do NOT reinstall swaybar
Do other side. Then install swaybar. Takes about 4 hours the first time. You will need large (up to 21mm) metric wrenches and sockets
Fritz
Old Sep 4, 2004 | 09:42 AM
OE812's Avatar
Fritz:
Thanks for the detailed information on spring R and R. If these 2" springs don't work, I guess I'll be kicking myself for not taking you up on your pepsi case offer.
Jeff
Old Sep 4, 2004 | 08:33 PM
OE812's Avatar
Installed the 2" lift coils and the truck looks great up high. The ride is like riding in a dump truck. Plus, the upper control arms are hitting at its' stop and the ball joints are hitting the springs. I guess I'm disappointed. I woulda coulda shoulda bought from fabtech.
Well, tomorrows were made for fixing the previous day's mess ups. I'm going back to OEM springs.
jeff
Old Sep 4, 2004 | 11:58 PM
Hey, if you have the Diet Pepsi, I still have the springs. They go into the trash in mid December anyway.
The ride with the Eibach springs wasn't that different from OEM. The small stuff felt a little rougher but the big bumps smoothed out.
Have fun.
Fritz
Old Sep 5, 2004 | 04:42 PM
OE812's Avatar
Fritz:
Wasn't too bad R & R springs second time around. It took me 2 hours plus 1 hour installing shocks. I've decided to save over the next couple of months for the 3" spindles on EBAY for $350 with shipping. Looking at alot of the posts in this forum, I feel that this is the way to go. Don't waste your time with the 2" springs. I think that any lift spring you use will adversely affect the A-arm and balljoint clearance on extended travel. There just isn't enough travel once you raise the OEM setup 1 or 2 inches. Go with the spindles.
My 0.02 cents.
Jeff
