Sponsored by: CARiD
Suspension Squeaking
Old Jul 20, 2004 | 10:09 AM
Adam Lynwood-Hi's Avatar
Angry Suspension Squeaking
My 99 F-150 4x2 with 66k miles squeaks under breaking and when I turn right. I thought it needed some lube in the grease fittings but I can't find where any grease fittings are. Supposedly it is lubed for life- so do I have a different problem?
Old Jul 21, 2004 | 07:43 AM
way fast witey's Avatar
its your leaf spring bushings mine started squeaking about that time i haven't gotten new ones and it hasn't really gotten any louder.you have 2 grease fittings on the idler arm and that's it,i know it sucks.hope that helped
Old Jul 21, 2004 | 04:16 PM
pushrod's Avatar
If the noise is coming from the front end, go to a parts store and get a needle for your grease gun. Then, carefully insert the needle between the joint boots and the joints. Inject as much grease as you can. Squeaks and pops will go away immediately.
There is no such thing as a maintenance free battery or lifetime lubed joints.
If the noise is coming from the rear end, try hosing down your leafsprings with WD-40.
Hope this helps!
Old Jul 23, 2004 | 11:28 PM
2byford's Avatar
My 2000 had a squeaking which was cured by lubing the sway bar bushings (by the dealer under warrentee). Heard it going over bumps and sometimes when braking. I don't know what he used exactly but do know it was a Snap-On product, if that helps. This was 2 years ago, and it hasn't come back. Same thing on my son's Ranger - same cure and same result. Hope that helps.
