Sponsored by: CARiD
Suspension Question
Old Jul 13, 2004 | 05:46 PM
rm328's Avatar
Suspension Question
I have to send one of my 22'' wheels back to the manufacturer for probably 1-2 weeks. I was wondering if I replace just that one wheel with the factory wheel if there would be any problems over time with the suspension. The difference in size in the wheels/tires is about 1-1/2''. Is this a good idea or not? Thanks in advance!
Old Jul 13, 2004 | 06:30 PM
Beardoge's Avatar
Absolutely will not hurt the suspension in a week or two...
Old Jul 13, 2004 | 07:49 PM
rm328's Avatar
OK thanks, I know it was a dumb question but I just wanted to be sure. Thanks again.
Old Jul 13, 2004 | 10:23 PM
max mitchell's Avatar
Do you mean 1&1/2" TALLER? If so, don't do this on the rear of a truck with the limited slip rear end or you'll burn out your clutches. On the front, be prepared for some pull to one side.
Old Jul 13, 2004 | 10:41 PM
jpdadeo's Avatar
Can’t possibly imagine what it could hurt. 1½” isn’t that much difference and two weeks isn’t that long either. I would put the odd size on the rear, LS or not.
Old Jul 13, 2004 | 10:43 PM
rm328's Avatar
Yeah, it is on the front driver side. If all it is going to do is pull then that will be fine with me, I just did't know if it would hurt anything. Thanks alot for the feedback!
Old Jul 14, 2004 | 01:50 AM
Mr_Bentwrench's Avatar
could cause abs concerns while you have different sized wheels but should go back to normal after you put the same size back on. would be a bad idea to put it on the rear that would cause wear in the differential.
Old Jul 14, 2004 | 02:30 AM
rm328's Avatar
Would it be better if I just go ahead and replace the front 2 wheels until I get my rim back or is it anything that I really need to worry about???
Old Jul 14, 2004 | 06:46 AM
jpdadeo's Avatar
rm328
It’s not going to hurt anything. It’s not going to cause excessive wear on the rear because it a LS. LS rears let the tires turn at different speeds all the time going around corners, that ‘s why you have a LS (limited slip) rear in the first place, not a locked rear. It also is not going to cause the ABS system to malfunction. Why? Just think about it, why? Don’t make a mountain out of a molehill, just put the factory wheel on and Go.
Old Jul 14, 2004 | 02:08 PM
rm328's Avatar
Re: rm328
Thanks, I really appreciate it. I'm gonna go find a hole to crawl into now!! j/k
Old Jul 14, 2004 | 04:03 PM
The limited slip is designed to slip the small amount of time that you go around corners. Putting 2 different height tires makes the LS slip all the time. The clutches are not designed to slip for extended periods of time. There has never been a competent rear end specialist that recommended running 2 different tire heights on a limited slip rear end. The reason why is because if someone gives incorrect mechanical advice, it makes them liable for the damage that may be caused.
Old Jul 14, 2004 | 05:29 PM
jpdadeo's Avatar
Clutch-Type Limited Slip
http://auto.howstuffworks.com/differential8.htm
Old Jul 14, 2004 | 08:00 PM
Thanks for the additional evidence against your viewpoint.
Old Jul 14, 2004 | 08:38 PM
jpdadeo's Avatar
you were right
