Sponsored by: CARiD
I have bad axle wrap...how to fix?
Old Jun 12, 2004 | 08:23 PM
1BADRIDE's Avatar
Ok, put a 6" skyjacker system on my 2001 F150 supercrew and i have a crap load of rear axle wrap.....bad enough that it caved in the side of my new rancho rxs9000 shocks! What is the best fix? New rear springs or does someone make ladder bars for the F150? I know fabtech makes them for the Superduty, but not for the F150. HELP!
Old Jun 13, 2004 | 02:04 AM
Crazy4Fords's Avatar
You can probably get traction bars for your truck or for $600 less install you could get new leafs from deaver, national, or atlas to name a few. With the springs you would get more travle out of them as well and vitually eliminate you axel wrap problem.
Old Jun 13, 2004 | 11:54 PM
JMC's Avatar
JMC
25 Year Member
1B,
Did you get the kit with blocks to raise the rear axle? Or did you get the kit with new springs. Adding blocks instead of using new springs will casue axle hop like you have.
A ladder bar will cure the problem for sure.
you will lose ground clearance but that is the trade.
Regards
Jean Marc Chartier
Old Jun 14, 2004 | 04:55 PM
1BADRIDE's Avatar
When I purchased the kit from The Auto Barn in grand rapids, michigan...I was told the kit had add-a-leafs. When it was on, it had blocks. Not only that, but my two front tires were trashed within 500 miles because they didn't do a front end allinement, nor did they tell me that it wasn't included in the installation. I've argued with them about it and i'm stuck forking the cash out for two new ones. Needless to say, I will never go back. You would think that they would take care of someone who spends $5500 getting a kit and gears installed and purchased from them, but I guess not.
Also, has anyone noticed the amount of yoke hanging off behind the transfercase on the driveshaft after the lift? I have alot of yoke exposed and tranny fluid everywhere under my body. Guess I'll have to get the axle extended too now....uggg.
Old Jun 15, 2004 | 06:14 AM
MANDRAKE27's Avatar
Hi there! I know RCD (racecardynamics.com) makes ladder bars for our trucks and they look awesome.. I have no experience with them though
Old Jul 13, 2004 | 02:40 PM
bigtruck311's Avatar
i had the same problem you did to fix it i added pro comp add a leafs and i took pro comp tractoin bars for a f150 2wd 8.8 rear axle and fabricatedted them to fit my 9.75 axl alittle grinding and measuring and it solved my problem perfectly
