Sponsored by: CARiD
Cv Boots
Old May 24, 2004 | 10:04 PM
JCHAPF150's Avatar
Cv Boots
ANYONE KNOW IF YOU CAN REPLACE JUST THE CV BOOTS OR DO YOU HAVE TO BUY THE WHOLE AXLE ASSEMBLY
Old May 24, 2004 | 10:55 PM
JMC's Avatar
JMC
25 Year Member
You can buy just replacement boots. Most partsstors should have them. FYI if one of your boots was torn you should clean and inspect the joint for dirt and debris and repack it with CV grease.
Regards
Jean Marc Chartier
Old May 25, 2004 | 02:18 AM
mg175150's Avatar
Yes you can buy either a split boot type so you dont have to take everything apart or you can buy the regular boots and go through the process of removing the hub assembly, rotor, etc. If you choose the regular boot you might want to consider just replacing the whole cv halfshaft right away (which is both inner and outer cv joints), since you will have everything already off. It will be a pain to have to remove everything again in a few months when your joint gose bad due to dirt, etc (unless you are certain the boot has only been torn for a very short time). My boot tore a ways back and I didn't notice it for a while. About a month ago the cv joint tore completely off of the hub assembly. It rattled around and screwed up the hub assembly also. The cv halfshafts aren't extremely expensive either.
Old May 26, 2004 | 12:29 PM
AWH's Avatar
AWH
this might be a dumb question
Is it important to inject your CV boots with grease as part of your routine maintenance? The F150 I now own is the first one that has ever had CV boots so I have no experience with them.
Old May 26, 2004 | 12:58 PM
JMC's Avatar
JMC
25 Year Member
No you should not have to inject grease into a sealed boot. The grease that came from the factory should last the life of the joint.
JMC
