okay i finally did it...i bought the lift
ok so after many months of deliberating, shoping, and asking questions, i bought a lift kit. i ordered a 3" spindle, add-a-leaf, 2" coils, and 2" blocks. i'm going to shop around for some shocks here in a little bit. so what i'm going to do is start spraying all the related parts with penetrating fluid til i put the lift on (which will be memorial day weekend), any other ideas for getting ready for the lift? also what's the best shock i can get for under $200 for all 4? any advise from experienced lifters on what to watch for/ tips on install/ etc? thanks guys. can't wait...5" of lift and then i'm going to put some 285's on (best i can do on stock 16" rim)
don't be stingy with the shocks, good quality shocks like edelbrocks IAS, Bilsteins, Ranchos, etc can make your truck ride 10 times better than cheapodepots!!!!!!
As far as advice, have some friends, jacks, and jack stands handy!!!!!!
yeah i understand about not going cheap, but i can't afford to drop another $400 on top notch shocks, i figured there's got to be a pretty good shock out there for around $50 a pop. jacks...check, friends...well there will be people there (don't know if they'd call themselves my friends
), jack stands...check. anything else guys? thanks
Hmmmm...the tin foil around the apartment must have done the trick cuz I couldn't get through with the telepathy!!
Congrats anyhow and post some pictures when you get 'er done!
ha ha... foiled again wild-mtn-rose. now some stainless steel brake lines...thanks for the great idea that's what i'm looking for. i was going to have to check out the brakes anyway so maybe i'll just add that to the list. i'd prolly have enough slack for a couple inches lift but not 5-6". thanks and keep 'em coming. oh, you better believe i'll have pics up when i'm done...just like a proud poppa
My advise would be that not to install the add-a-leaf AND a 2 inch block. I've got 7.5 inches of lift in the front of my truck and I have 1.5 inch blocks and add-a-leafs and the front sits 1 inch higher than the rear. If you like the rear being higher than the rear, both will be fine. If you want the rear end more lever or a little lower, go with just the blocks since the add-a-leaves make things a bit stiffer in the rear. See here for yourself
interesting, i'll keep that in mind...i'll take some measurements and see what i think before i put the rear block on (i'd like the add-a-leaf cause i'm going to do some towing). thanks...ohh and nice looking truck
where's the best place to get some longer brake lines? i'll probably need some when doing the lift i figure and i'd like to have them before i start next weekend. thanks guys
If you want to save some money on shocks but still get something that is pretty good I would suggest trailmaster's new shocks...A guy that owns a local 4WD center here swears for the price they cant be beat. He was telling me about their new valving they are using...Now I dont have them so I cant say from personal experience, but he is a good guy and is honest. I would have went with them if I had not already bought my Edelbrocks.
trailmaster shocks eh... never heard of 'em... i'll more than likely be going out to the 4 wheel store this week and see what kind of options they have. ok everybody, pray for no rain in ohio this memorial day weekend...please
